yes very much so haha it moved my LMT's the full 50mm off 800 watts per sub...so wait wouldnt bass i love you damage your woofers?
yea i had my SSF up pretty high and they still moved like none other loldepends on where ur SSF is set at, most people have such high tuned box's and the SSF is usually around 30-35hz that ur subs probably wouldnt even see the 10hz frequency from the amp. Ur amp has to be able to reproduce the frequency as well. Like his IA's can amplifiy from 10-350hz.
Keep in mind that the frequency response of an amplifier doesn't mean that outside of that range the amplifier ceases to operate...only that the response is no longer flat and has began to rolloff.depends on where ur SSF is set at, most people have such high tuned box's and the SSF is usually around 30-35hz that ur subs probably wouldnt even see the 10hz frequency from the amp. Ur amp has to be able to reproduce the frequency as well. Like his IA's can amplifiy from 10-350hz.
If by "all the levels" you mean all of the frequencies.....it's because you were hearing the harmonic distortion the subs were producing rather than the actual fundamental frequency.how come on that hoods run down song i could hear all the levels off of 2 10" w0 in a regular cab truck(my first set up)
I didnt know that, So it works like a X-over point?Keep in mind that the frequency response of an amplifier doesn't mean that outside of that range the amplifier ceases to operate...only that the response is no longer flat and has began to rolloff.
You could think of it in somewhat the same sense, in that the frequency response is normally rated by when the response has rolled off by some rate, such as -1db or -3db.I didnt know that, So it works like a X-over point?
you will hear notes lower than what the x-over is set at due to box design and transfer function.You could think of it in somewhat the same sense, in that the frequency response is normally rated by when the response has rolled off by some rate, such as -1db or -3db.
