How long until my battery charger is stolen?
Yea man, sorry to tell you but if you want more power with the car off you're just gonna need to get different batteries. I'm not sure if your sundown amps would complain off 18v batteries, but they make em.
Just curious though, why do you need so much power with the car off? If you're competing can't you just leave it running??
His sundowns can handle 18v //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
All the power he has will drain his battery, voltage drops = no bueno //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
//content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif the charger is actually working
I disconnected the charger after 5 hours and started the car... idling a little above 13 volts...which means everything is great //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Just gonna let it sit for 8 more hours or so before I go to work.
After you take the charger off, let them sit for a little bit, and then measure the voltage.
Hey bro, you get your blue top yet?
AutoZone does free charging just so you know if yours isn't charged.
The charger has been on for 12 hours, I took it off and waited 20 minutes. Getting 12.8 with car off, 13.1-13.2 with car on... but keep in mind that it's probably no where near fully charged, there are 7 **** batteries.
You need to get your alternator fixed...
stock or after market alt? i never seen a stock car that worked right idle voltage under 13.8 and that 13.8 was a 2003-4 audi quatro. if it doesnt produce voltage it needs at idle its battery powered until it hits the right amount of rpm. what people do to help that with after market alts is put a smaller pully on the alt or worse yet is turn the idle up which i wouldnt do...
Kenny Pollock
drag it!
Kenny Pollock
Hollywood, Florida Low: Yes
audiolife
