How high can you set the volume on a Alpine deck, (7995 or 7894)?
It dosent matter how high it gose. The Alpine kicks in the sound and loudness at lower volumes so it dosent have to go up to 40-50. As for the panasonic dosent get loud intell higher volumes. My alpine get very loud befor it hits 20.
it really doesn't matter how high your deck goes. If it gets 140 watts from 1-20, then from 21-40 its only gonna get 60 watts. Its all about how your amp. inside your deck is set. Matt
this really depends on if your useing an amp with it or not, the alpine will get just as loud as any other deck out there. if you are useing a external amp with it though, it will depend on how you have your gains set. the general rule is to set your volume 2/3 up and set your gains till your speakers start to distort (going very slowly) then back it off a little.
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
302
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
906
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
759
nofriends46
nofriends46
Hawaii, Kauai
adamS
