how hard would it be to make this box?
About 4 or 5 hours maybe. He!! I don't really know //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif . I'll check it out and see. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by ramos About 4 or 5 hours maybe. He!! I don't really know //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif . I'll check it out and see. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Lol, cool.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
- Steve
Boonies ..... I couldn't really tell ya that. I can't tell them apart from the rednecks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If you were able bend the plexi, wouldn't that corner of the box also have to be curved? Why not use two seperate pieces and drill/screw/epoxy them together? Use something thick like 3/4 or even 1". If your using 1"mdf then go w/ 1".
Or, if your conserned about mounting the plexi, if your using 1" mdf, go with 1/4 or 3/8 plexi, router the edges and drill/screw it down that way. I'd sill go w/ 2 seperate pieces, and the thicker the plexi the better...as far as flexing is concerned.
Originally posted by Trixter If you were able bend the plexi, wouldn't that corner of the box also have to be curved? Why not use two seperate pieces and drill/screw/epoxy them together? Use something thick like 3/4 or even 1". If your using 1"mdf then go w/ 1".
That would work. Just use plexi adhesive and the joint will be almost invisiable. The thikness really depends on the power your talking about. And the actual size of the panels. 3/4", and 1" plexi is some pretty strong $hit. You realy don't need to go to those extremes unless your way up on the power scale. People use 1" plexi for windows in extreme cars. That's alot more pressure than your average joe is ever going to put on it. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by ramos That would work. Just use plexi adhesive and the joint will be almost invisiable. The thikness really depends on the power your talking about. And the actual size of the panels. 3/4", and 1" plexi is some pretty strong $hit. You realy don't need to go to those extremes unless your way up on the power scale. People use 1" plexi for windows in extreme cars. That's alot more pressure than your average joe is ever going to put on it. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
not to mention freaking expensive out the ass. i was pricing 3/4" plexi a while back that stuff was like 400 bucks for a sheet and that's the only way you coudl get it.
adam
In that case, the second option sounds a little better then.
d audio 450
Registered User
d audio 450
Pa Philly area
Trixter
    May 18, 2024
    May 16, 2024
