How hard is it to carpet a box?
It will run you 10 bucks a roll of carpet from walmart. You may need 2 at the most. A can of adheasive spray will be about 5-10 dollars.
(Im assuming you already have a razorblade handy)
Working diligently, you can have a box carpeted in an hour or less.
$8-$20 carpet, $4 spray glue, $2 blade.
The hardest part are the two edges of the box where the carpet needs to be cut in an X. After a couple times you get better. The first time is not going to line up and look perfect. Unless you get lucky. Just follow the guides available online and you will be fine.
kingsxman
Noob in training
kingsxman
Minneapolis
johnson
michigan born
    May 14, 2026
michigan born
    May 14, 2026
