How do you Strap two IA 40.1's together
3) I am looking at the manual but still can't figure out how to strap the amps. - 3/13/07
This seems to be a common problem so it's not just you. I hooked up the wiring on a pair and snapped some actual photos to help you out:
The master amplifier gets the input from the head-unit and a mono RCA from "BR Out" connected.
The slave amplifier ONLY gets "BR In" connected from the master.
ALL controls are handled on the master, setting anything on the slave is not necessary.
This picture should be pretty self explanatory.
* The slave takes the "-" connection(s)
* The master takes the "+" connection(s)
* The "-" terminals of the amps are hooked together.
You don't need to use both sets of "+" on the amps. They are there for flexibility. While you should always connect both "-" terminals on the amps together using large wire as general procedure it is not absolutely necessary to use both sets of "+" terminals. They are connected together internally in parallel.
When strapped the MASTER controls ALL functions of both amps.
There's the post from SSA, very helpful.
*I am not taking credit for this information, full credit of the post goes to Jacob. I simply copied it from the link posted above since you said it wasn't working for you.*
Korn4Life
SUB LOVE
Korn4Life
PA
x2o
