babaganoush123
how do you do multiple runs of 0 gauge wire? i might do the big 3 so i need to know because i might grab a 250amp alt and 3 yellow tops??
x2 and use distros/aluminum or copper buss bars. Some use pvc pipe and run the wires threw the pipe underneath the vehicle.most people cut a bigger hole in their firewall and run the wire under the car's carpetand be more specific with your question next time*
most ppl shouldn't cut holes in their fire walls, they are that way for a reason - they are firewalls - most cars have have rubber gaskets under the carriage that can be cut out/modified for cables.most people cut a bigger hole in their firewall and run the wire under the car's carpetand be more specific with your question next time*
IMO - I would post what you intend to install and find out exactly what you need in the terms of power - in terms of equipment etcyea i already made the hole through my firewall. im just confused on how to have multiple runs. that increases power right when you have alot of watts?
Dude, it's just like how your speaker wires have a positive and a negative. If you twist the two ends together, they become one bigger wire and creates more watts!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifyea i already made the hole through my firewall. im just confused on how to have multiple runs. that increases power right when you have alot of watts?
