*How do you connect BATTERY ISOLATOR??*
  • 4
Go to the fuse panel in your car. Either by using the diagram, or a DMM, locate a circuit that is ignition switched (only powers up when ignition is turned on) and run a wire from that directly to the isolator.
345
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
500
I agree; it doesn't. :) See my comment above on Tuesday at 4:08 pm; in short, I'll use the auxiliary port on the FM transmitter.
The end result is, not the intention. I think OP got what I was saying. The Brits generally aren't as sensitive. A 500w sub amp does not...
17
swollen_cu
swollen_cu
New Orleans
mast240
    May 12, 2024
Brendon Jenness
    May 11, 2024
