How do you connect 4 mono amps??
You should still use the front/rear preamp outputs for the 4 channel amp so you can still use the fading function.
Does your mono subwoofer amp have RCA outs on them so you can daisy-chain? If not then you'll need a line driver for your subwoofer amps because you can't split the subwoofer signal from your headunit to that many amps - the preamp will clip and probably sound horrible.
appleyard
Fulltime Amateurs
appleyard
Kota Kinabalu
appleyard
