how do u do a big 3 on a 99 civic?
how I do it, I guess it would be the "Big4" in my case...
from you battery to you alternator
from your battery to your chassis
from your battery to you engine block
from you chassis to your engine block
well i know how to do it!
i didnt know what to wire wat to!
as in this battery to alt
battery to chassis
chassis to engine block
thanks k_schutte for the right reply
well i know how to do it! i didnt know what to wire wat to!
battery to chassis
no you dont, sorry, not trying to be a dick, it is the same on every car ever made in the history of cars, if you knew how to do it then you wouldnt have started a thread
well jdawg u shudn't reply to post if ur wanting to be a dick! im trying to learn all i can!
im sure its all the same!
i didnt know what the setup was so i started a thread!
so thanks dick!
thanks Jh8909 for the other info
redundant because 2 and 3 do that
actually no they dont, pop your hood, are your motor mounts solid steel? unless you have a custom built drag car then I doubt it. Your engine grounds through the bolts that go through your motor mounts to the chassis, and it always isnt the best. If you want to get real technical then you should also ground your alt to your chassis, it bolts to a bunch of brackets that bolt to the engine then try to ground through rubber bushings, then to your chassis. Of course every car can or cannot have a problem there.
battery to chassis | battery to engine block
chassis to battery | battery to engine block
chassis to (battery | battery) to engine block
chassis to (battery) to engine block
The 4th is equivalent to the 2nd plus the 3rd, the tie being the connection at the battery. It would be significant if either the 2nd or 3rd wasn't present. It is redundant when both 2 and 3 are present.
battery to chassis | battery to engine block=
I dont think im understanding or you are not, battery to engine block and battery to chassis is not the same thing. In a perfect world it would be. But your engine is connected to the chassis through brackets and rubber motor mounts. The grounds work fine for factory stuff but not a high powered stereo system.
I'm not saying they are, you must be misunderstanding me.
Take the chassis to engine block wire. Imagine a point half way in that wire and stretch the wire to connect that point to the battery while leaving the original ends connected. What do you have? 2 wires; 1 is a chassis to battery, 1 is an engine block to battery.
Get it?
if you pop your hood you will see a ground wire going from your engine to chassis on the right side of the engine. there is also one on the left side from your transmission to chassis(you have to take off the airbox to see this connection)
alt to batt is self explanitory. batt to chassis is self explanitory.
/thread.
Frische44
Frische44
Sevierville,TN
k_schutte
