I was going to say "if you have to ask how to do it, you don't need it" but I decided to be niceI think in your case you let someone else do it
no you dont, sorry, not trying to be a dick, it is the same on every car ever made in the history of cars, if you knew how to do it then you wouldnt have started a threadwell i know how to do it! i didnt know what to wire wat to!
as in this battery to alt
battery to chassis
chassis to engine block
thanks k_schutte for the right reply
redundant because 2 and 3 do thathow I do it, I guess it would be the "Big4" in my case...
from you battery to you alternator
from your battery to your chassis
from your battery to you engine block
from you chassis to your engine block
actually no they dont, pop your hood, are your motor mounts solid steel? unless you have a custom built drag car then I doubt it. Your engine grounds through the bolts that go through your motor mounts to the chassis, and it always isnt the best. If you want to get real technical then you should also ground your alt to your chassis, it bolts to a bunch of brackets that bolt to the engine then try to ground through rubber bushings, then to your chassis. Of course every car can or cannot have a problem there.redundant because 2 and 3 do that
I dont think im understanding or you are not, battery to engine block and battery to chassis is not the same thing. In a perfect world it would be. But your engine is connected to the chassis through brackets and rubber motor mounts. The grounds work fine for factory stuff but not a high powered stereo system.battery to chassis | battery to engine block=
chassis to battery | battery to engine block
chassis to (battery | battery) to engine block
chassis to (battery) to engine block
The 4th is equivalent to the 2nd plus the 3rd, the tie being the connection at the battery. It would be significant if either the 2nd or 3rd wasn't present. It is redundant when both 2 and 3 are present.
I'm not saying they are, you must be misunderstanding me.I dont think im understanding or you are not, battery to engine block and battery to chassis is not the same thing. In a perfect world it would be. But your engine is connected to the chassis through brackets and rubber motor mounts. The grounds work fine for factory stuff but not a high powered stereo system.
