How do I wall
Based
I was going over thoughts on walling next year... And I was just wondering if I could get a couple simple questions answered here while I'm googling...
Is a wall just a box that blocks off everything behind the box?
I only need a 14 cube box... So do I just make a 14 cube box and fill the sides, floor, and roof gaps with wood?
Does the entire area behind the back of the box need to be filled or can I put my amp and batteries back there?
I've never built a box before, should I even be thinking about building a wall????
A wall is mainly wall to wall taking up the largest space possible.
If you have a hatchback or suv then mounting amps behind is possible, but again a wall is a almost sealed off box.
You dont want to leave TOO MUCH space behind as you will lose cabin space for unneeded box space.
Sent from my HTC Glacier using Tapatalk 2
I don't understand your last sentence, maybe I'm tired :p.
I don't get why it has to fill the entire back space. I thought as long as it blocks off the back of the cabin from the front it's a wall. Isn't the reason walls are loud is because they cut down the air the subs have to displace?
---------- Post added at 07:54 PM ---------- Previous post was at 07:53 PM ----------
An example for my last sentence is, you dont want to make a wall in the middle of your vehicle because then you are leaving space that doesnt need to be left.
As for why a wall is louder is because you have less chances of cancellation. The air being pushed will go one way and wont have a chance to go back making the sound bounce causing cancellation.
Sorry if im not making sence, but its harder to explain without showing how it works in a graphical picture.
Ok, I drive an extended cab truck. It has a front seat and a back seat. So keep that in mind when I ask this:
so would it not be ok if I made the box in the middle of my cabin, leaving maybe a little less than half of my back seat area empty?
No. That's not a wall. You have to completely seal it from the back wave. This is not something you want to jump into. They hardly work right the first 5 times.
Is there like a write-up I can read explaining the basics of this?
I have a truck also and have 2 options.
Make a wall built around the bucket seat with 2 ports made to spec.
Or make an entire wall with a large port so you can make external ports which can be bolted over it kinda like a aero port, but just being a huge slot port.
Just remember the bucket seat idea needs to have a wooden wall behind it or else you will lose spl.
Based
Based
Louisiana
mlstrass
