How do I know beforehand if Im going to need a new batt/alt?
omizzle
DB Drive Platinum
I have an '01 Saturn, 4 cyl.
Im going to be running a 1600 watt bxi1606d, with a pair of 12" db drive platinum (750 rms)
Im wondering If I have enough engine power for an amp for my frontstage... should I just use my deck (880prs) to power my frontstage?
Take the maximum amperage that the amp will pull ( prob 80A)
Then check under the hood and see what the maximum amperage of the alternator is.
If its less than 80A you will probably have some dimming on heavy bass.
The battery in that car is small as it is, definetly garbage.
Take the maximum amperage that the amp will pull ( prob 80A)Then check under the hood and see what the maximum amperage of the alternator is.
Dont forget the 10A the deck uses up... and any other stuff...
Unless the volume is full and powering speakers it wont pull 10A The headlights pull about 30A
Which most ppl like loud music and most decks power speakers... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Unless external amp... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif [i know Im giving ya a hard time...] //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
30A on lights! Dayummm... that I didnt know
Don't forget the A/C and the fuel pump and the engine fan and the engine computer. There is not a lot of headroom on most alternators. It simply isn't economical for the car maker to spec a larger alt than the car needs to function. Trucks typically have a little more slop to work with.
Chances are that you will need to beef up the electrics in your car.
Find out what your alternators amperage is at idle. Make note that your Alternator prob wont put out it's full rating ever.
From there you can figure out if you need an upgrade. I would say for a Sub 1000watt setup most of the time The Big 3 and a Good car battery would do.
More than that and you're asking for trouble.
My lights dim Bad. I have a 130a Alt. It puts out 70a or so at idle. I'm pushing 1200w rms to my subs, 125w rms to components.
havent done the big three yet. Planning on changing the alt soon.
omizzle
DB Drive Platinum
omizzle
Indiana
DoobieBrother
