Or you can go with a large sealed box stuffed with polyfill and it will go low low. You can do ported but tuning to 20hz with enough port area is a pain and will result in a huge box. Here is a little article from JL and boxes.
Sub-30Hz Behavior
Sealed box designs and single-reflex bandpasses are much better at controlling excursion at extremely low-frequencies (below 30Hz.) For this reason, they can usually handle more power in these frequency ranges than ported designs and dual-reflex bandpass designs which makes them less prone to low-frequency induced speaker damage. At frequencies below the tuning frequency of the port, a woofer in a ported box (or a dual-reflex bandpass) starts to de-couple. This means that the controlling function of the enclosure begins to disappear. The collapse is gradual rather than immediate, but at some point below the tuning of the port, the speaker behaves as if it were operating without an enclosure and suffers from potentially damaging over-excursion. (This is why it is a good practice to use a sub-sonic filter when running a ported enclosure or a dual-reflex bandpass. Some high-quality electronic crossovers like the AudioControl 4XS incorporate a programmable subsonic filter circuit.)
Related to the loss of enclosure damping, ported and dual-reflex bandpass designs also exhibit higher distortion levels at very low frequencies than sealed or single-reflex bandpass designs. The importance of this is questionable, however, since little program material extends to below 30Hz.
Sealed enclosures and single-reflex bandpass designs have a rather shallow low-frequency roll-off rate of around 12dB/octave, whereas ported enclosures and dual-reflex bandpasses typically exhibit 18- 24dB/octave roll-off. For this reason, sealed enclosures and single-reflex bandpass boxes can have much higher -3dB points (the frequency at which the output dips 3dB below the reference efficiency of the speaker) than ported designs while still producing very good ultra-low frequency output.
