PrestigeSounds
You've got 4-4 ohm woofers and your trying to wire them up to an amp that handles a 1 ohm stable load? You want to run what is called series parallel. Take each speaker and connect one of the negative terminals to one of the positive terminals on each woofer. You will then connect the remaining positive terminals of each woofer together with a lead extending off the final terminal to be fed into the amp. Then take all remaining negative terminals and connect them together, again with a lead off the last speaker to feed into the the negative terminal on the amp. Just basically how the image provided by Maxi explains it. Pretty simple...
