How do i hook a mids and highs amp and a mono amp
  • 2
how do i hook but these amps up. I already have a mono sub amp and just want to hook a mids and highs amp.How can i do this with a distro block for the power wires
Well you kind of answered your own question, you use a distribution block...derp
and what about rcas? how many runs do i have to have of those to my radio.
Well you have one set for your sub which presumably come from a 'sub out' on your deck. You'll then need another set (left and right, two channel) for your mids/highs if your just amping the front speakers or if you don't care about front/back fading. If you're amping all 4 speakers (front and rear) and want to be able to fade front/back you'll need a four channel rca cable.
Alternatively if your subwoofer rca cable is being fed from a full range output you could just split it in the rear at the amps.
what u mean split at the rear at the amps im sorry for the dumb question.
One cable goes in, two come out...
324
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
southport2014
southport2014
Indianapolis, IN
bubbagumper6
