How do I fix this????
oxsign
No Affiliation
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
just toss it in the trash //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
No //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Duh //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Cyanoacrylate (CA) + rubber glue.It works wonders, stays flexible and will NOT let go.
http://www.hobbyhorse.com/glue.shtml
Second one down.
Thank you for the info. I'll see if I can find a local shop that might have some of that.
wouldnt the rubberized CA glue (black) work better for rubber to metal? in my experiences it will since it doesnt cure as hard as the clear stuff and can flex some more without the bond breaking loose
dont buy tc sounds subs? //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
..ok had to crack that one....anyways, that was a common problem at one time.
Don't use the BSI rubber toughened unless you plan on throwing the bottle away after you use it since it literally has zero shelf life once you've opened it up. And you WILL need the Accelerator with it, or you'll be waiting a freakn week for it to dry properly.
My suggestion - Use the BSI Ic-2000 Maxi cure (in a pink label bottle) with the Instaset accelerator. That's all I use these days for all of the recones I do. I won't touch the Toughend Rubber (black) glue anymore.
do you know if this is something that can be found at a hobby store? Or is this somethng that has to be ordered online? Just asking, I'll be swinging by one on the way home.
oxsign
No Affiliation
oxsign
Orlando, FL
Ronmeister
