How do I cut plexiglass?
MetalMaxima
AURAL DESTROYER
Any recommendations for cutting plexiglass? I am thinking that I could use a fine-toothed jigsaw blade, but I still run the risk of chattering...or I coiuld just use a dremel cutting wheel, but that would take hellua long if I went that route.
Any suggestions?
PS...Score and snap doesn't work...this I know from experience //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
What the hell are you talking about, flying off. If you score the the plexi deep enough you can just crack it. You could also take your plexi to a tru valu or something like that because they will cut plexi for you as long as it is not an odd shape.
Thanks for the replies, fellas.
I actually wound up using a dremel with a cutting wheel and a sanding drum to cut rectangles for my amp rack with rounded corners...turned out beautifully!
MetalMaxima
AURAL DESTROYER
MetalMaxima
The Garden State
MetalMaxima
