How do I connect the amp to battery?
dirtbagz89
dirtyTHIRTY
Never installed an amp or subs before.
How do I connect the amp to the battery? My battery is in my trunk by the way (08 Pontiac G5)
I have everything hooked up except for the ground and power wire.
Do I hook up the power wire from the amp to the positive connection on the battery?
Do I need a fuse? I bought an amp kit before that has a fuse holder with a 100a fuse.
The amp appears to have 2 15a fuses on it already.
And then I just connect from ground on the amp to ground somewhere on my car right?
I can't find anyplace to ground to.
yes run wire from the positive terminal on the battery to your amp. And yeah you want to put a fuse block between the wire for safety. And find any place near the amp to ground. Look for any bolt that connects to a piece of metal of the car. Make sure when you ground whatever bolt you use, use sandpaper to scratch of all paint on that spot for safety reasons as well
Lol...almost everythings plastic back there.
dirtbagz89
dirtyTHIRTY
dirtbagz89
Buffalo, New York, United States
bass-aholic
