how do I ad the driver displacement?
Orion H2s have significant motor assemblies.
The tuning frequency generated by that calc will be different than actual, since it doesn't exclude displacement from the port calculation.
so how do I make a 4cu.ft NET ported box tund to 30hz for a mj-18 on that calc
What the **** are you trying to do? What don't you get? Get the real driver displacement and design an enclosure with the net volume taking into consideration the driver displacement. It's really not confusing at all.
All you have to do is this: add the driver's displacement + the cubic feet you want from the enclosure...= gross box volume = RE's "Box Volume (Ft3)" figure.
Example: If you want 2 cubic feet and your driver displaces .4 cubic feet, you need to design your box so RE's calculator gives a value of 2.4 cubic feet of box volume.
think you that is what I wanted to know:pissed: .......
so it will still be tuned to 30HZ right
//content.invisioncic.com/y282845/emoticons/suicide.gif.a649d21efc0d1fd4890a6428166586c1.gif
You'll have to mess with the enclosure's dimensions to get the tuning and cubic feet you want to achieve. The best way to change the tuning is to fiddle with the port dimensions.
OMFG, I actually answered a question instead of asked one. Yay!
//content.invisioncic.com/y282845/emoticons/graduate.gif.d982460be9f153bb54e5d4cb744f6ae8.gif
Be careful with that box building program, I recommend checking it with a few others and WinISD before you actually build...
Always check the cuft by hand...
what's WinISD link?.....so what do you think the mj-18 is 0.473 http://www.reaudio.com/speaker_box/LPort_Box_Calc.html
my goal is to make a 4cu.ft box tuned to 29hz NET so what do I do make the port
longer? shorter?
what is OMFG? order my fart gas ???
10
398
Heck...done right...you could get an amazing sounding stereo using $15-25 drivers from partsexpress 😂
673
28
Yes, time to move some stuff for sure. Have a little mini CA warehouse in the garage!
10
703
jeremiah
edit me but not ****? ok?
jeremiah
Canton Texas
jeremiah
Brendon Jenness
    May 8, 2024
    May 8, 2024
