How and amp run cool??
I think that amp heat more when running lower resistence 1ohm and down, i want to know how it will run cooler 2ohm stereo, or 4ohm mono, or it'll be the same.
Talking about amp temperature.
Thanks.
Ah, I was about to get mad then I realized you are from. The amp will be seeing the same load wither way so It should run about the same temp. Now 4 ohm stereo would be cooler than 4 ohm mono, But i think you know that already. I assume you are using this for a sub, so go 4 ohm mono.
Symon_say
You can't get me
Symon_say
Dominican Republic
dleccord
Mike Mccabe
