Hooking up my Amp.
  • 4
menace68
Could you please Help me?I have a Pioneer-CD-Radio with 2 RCA Pre-outs and have a Sony 4-channel amp. Should I hook-up the speaker wires to the amp-should I hook-up the RCA Pre-outs-or should they all be hooked-up? I also have 4 aftermarket speakers.
you can do either or.
if rcas are ran just connect those.
if you want to change/mess with setting on headunit too, then use the rca outputs
rcas will probably be your easiest/best choice, so you dont have to splice into factory speaker wires. especially if you took them out.
A set of these at the amp https://www.amazon.com/dp/B08669YZDJ/?tag=caraudiocom-20 Then the sub out to the amp. Important that you are using 4...
28
  • Locked
243
Amp
275
342
menace68
menace68
Audubon,Iowa
CrossoverOre
    May 12, 2024
Brendon Jenness
    May 11, 2024
