Hooking up 2 coaxils to 1 hu channel?
Yes, by wiring it that way you would either have a 2 ohm load or 8 ohm load depending if they were wired in parallel or series, respectively. I'd suggest amping your speakers if you can, your HU doesn't put out much power at all.
Your headunit will most likely not like a 2 ohm load. It will probably work under low volume levels but overheat and turn off and high volume. Either wire them to 8 ohm (in series) or amp them.
So what if I use a 4 channel amp to power some mids and tweets could I then use my front and rear channels off my hu for coaxils in the dash and rear doors?
If you have a 4 channel amp there is no reason to run ANY of you mids or highs to the radio. Run all of your door/dash speakers on the amp.
Bass Face84
Sulpher Springs, Texas
UsAmpsFreak
