hi guys!
well, im trying to upgrade my electrical in my 95 probe gt and so far, i have done the big3 and am using 0/1 guage runs to the hatch from the engine battery.i will soon get a yellow top or a another kind of gel cell. i was thinking of a different idea in my case. i have an excellent running engine and stock alternator
the hoods are REALLY low to fit almost any kind of battery except the stock size and i may have a problem putting a larger size in there. space is VERY limited. so i was thinking the following..
what if i left the stock 800amp engine batt. as is, with all my wiring still in place going back to my amps in the hatch, then buy a gel cell, BUT run it seperate, on its own (not connected to the engine), in the trunk to give the amps some extra juice ?? i know it may sound "very different", but with a gel cell, id be able to mount it any which way or hide it in the trunk and then i can always take it out and charge it on my portable recharger in the garage. i know it may seem like a lot of work and i know the obvious response would be to get a H/O alternator. but not trying to cut corners, and since my stock is running fine, my luck id do more harm than good trying to install the thing, plus they are fairly pricey. this method is bascially trying to avoid the H/O alternator as an option.
what do you guys think? sound crazy? pros/cons?
any input is appreciated! thx
