Home made vs prefab
If homemade really should be done, what do I need & what program can help me?
Here are both my subs:
TS-W309D4 - 12" Champion Series Subwoofer with Dual 4 © Voice Coil | Pioneer Electronics USA
Currently have them in a ****** sealed enclosure.
http://www.audiosavings.com/products/12-inch-Dual-enclosure/Rockville-RDVB12-Dual-12-1.75-cu.ft.-MDF-Vented-Ported-Subwoofer-Enclosure-Box/RDVB12.aspx
This box is ported & rated at 1.75 cu ft (which according to the specs of the sub are in range)
Thanks in advance for input.. .learning rookie here
A custom enclosure lets you run the volume, port area and tuning that will both meet your output and response goals, as well as letting the sub be as efficient as possible based on the power its seeing. Your sub has a pretty high Qts of 0.81 so its much more suited for a sealed application. If gaining output is what you're after, a 4th order would be the way to go. If the sub is seeing rated power, you could go factory specs sealed, then do a 1:2 ratio to keep things daily.
If homemade really should be done, what do I need & what program can help me?Here are both my subs:
Audio Savings | Rockville RDVB12 Dual 12" 1.75 cu.ft. MDF Vented/Ported Subwoofer Enclosure Box
WinISD is a free download and will help you model different box designs.
You will need to discover Fs, Qts, and Vas of your woofers to predict response (should be available in the manual or on Pioneer website). Be careful of units with your design software, if Vas is in liters for example, just click on the l until it becomes ft^3 if you need cubic feet, change meters to inches, etc.
Lube
Lube
United States
hispls
BP1Fanatic
BP1Fanatic
