Highs and Mids question
ChaseinBass
I am running a set of Cdt hd62AS comps / 6.5 mids and 1" tweeters and another a set of tweeters-they call them front imaging tweeters and 2 way passive crossovers and i have them run off a kicker 400.4 amp and ordered a PPI 900.4 amp. I am wondering should i use the passive crossovers or should I try and run them active. What is involved and pros and cons ?
Whats the benefit over what i have now ? more tunable i suspect ?
Active all day.Just need to have your crossover points set properly for each set of drivers...
80hz-100hz hpf, 3.5 - 5khz lpf for mids
3.5k to 5k hpf fur tweets.
12db+ slopes.
Play with points and slopes..
Yep. more tunable.
Problems in a passive set that you can't fix, can be fixed (most of the time) in an active setup.
Why get into car audio without being able to freely tune //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ChaseinBass
ChaseinBass
Calif
calebkhill
