okay, easy way to settle this: apparently, none has actually seen the efficiency graphs of different amplifiers. look them up, and i hope you find them, and not just take my word. every amp has a max efficiency point. some are at higher impedances than others, but the point is that max efficiency is at/near the amplifiers full clean potential. the only real way to tell is to actually tell, is to measure rail sag and watch where the voltage drops beyond a typical operating slope, or even drops some on particular amps with a good rail regulation. A good indicator i look at, is rms doubling with ohm load. take, for instance, your 600rms@1. if it does 300rms@2, and 150rms@4, then i would have to say that power supply is in the lower operating range at 2 and 4, which would be typically 40-60%, sometimes less. now, your other example of a 1500 that does 600@4, then it would be doing 375@4 if 1ohm was the most efficient. likely, that would be an amp that likes 2ohm, where it is efficient, but not overly strained and heated. old school kicker amps were a good one to look at. they gave the 1,2,2.66,4, and 8 ohm ratings. 2.66 is where they reached most efficiency. usually looked like this: 37.5@8, 75@4, 125@2.66, 125@2, 100@1. so basically, in your example, the 600@1 would be more efficient than the 600@4.as for the optimas, i've been saying that for a while. last year, or 1.5-2years ago, i threw out 13 optimas. last winter, my best friend pulled in the driveway with his newer yellow-top swollen like i've never seen before, and i have 2 more yellow tops, and 1 red top i have to go drop-off for disposal. then, there is my last red top, which i have to try and save, but it might just be toast like the rest. i run an x2power in the daily.
