akheathen
Premium Member
trianoacitol contraceptiv
ok, i still didn't grab the clamp yet, but i did take some profound quick numbers on imp. rise........ i was testing an amp i have on the bench with a 500w koiiler 12" in about 1.2 sealed. 2 sweeps, and you would be supprised how far off the wattage is without clamping. so, it's a 4ohm, and i played 2 tones @ 36, and 57hz. here are the #'s
57hz= 18.24vac @13.5vdc should be 83watts, but..... 1.26a means, it was actually sitting @ 22.98watts @ 14.47ohms
36hz= 17.3vac @12.9vdc should be 74.8watts, but..... 2.5a means, 43.25watts @ 6.92ohms
so, the 83watts=23
75watts=43
oh, and that was with the gain set at 20.3vac@57, and 20.5vac@36(didn't touch the settings at all once there wan no audible distortion, etc), and the ps voltage sitting @ 14.7 unloaded. although, there was no way of measuring clipping, i still think this kind of illustrates an average condition, similar to the one in question.....
so, the 83watts=23
75watts=43
