Taken from JL 500/1 Manual
necessary equipment
• Digital AC Voltmeter
• CD with a sine-wave test tone recorded at
0 dB reference level in the frequency range
to be amplified for that set of channels
(50 Hz for subwoofer channels, 1 kHz for
a midrange application). The CleanSweep®
Calibration Disc contains the appropriate
test tones and is available for sale at
JL Audio Mobile - Home Do not use attenuated
test tones (-10 dB, -20 dB, etc.).
the nine-step Procedure
1) Disconnect the speaker(s) from the
amplifier’s speaker output connectors.
2) Turn off all processing (bass/treble, loudness,
EQ, etc.) on the source unit, processors (if
used) and amplifier. Set fader control to center
position and subwoofer level control to 3/4 of
maximum (if used to feed the 500/1v2).
3) Switch the “Input Voltage” switch to “Low”
and turn the “Input Sens.” control all the
way down.
4) Set the source unit volume to 3/4 of full
volume. This will allow for reasonable gain
overlap with moderate clipping at full volume.
5) Using the chart on this page, determine the target
voltage for input sensitivity adjustment according
to the nominal impedance of the speaker system
connected to the amplifier outputs.
6) Verify that you have disconnected the speakers
before proceeding. Play a track with an
appropriate sine wave (within the frequency
range to be amplified by the 500/1v2) at 3/4
source unit volume.
7) Connect the AC voltmeter to the speaker output
connectors of the amplifier. If the channel
pair is operating in stereo, it is only necessary
to measure one channel. If bridged, make sure
you test the voltage at the correct connectors
(L+ and R–).
8) Increase the “Input Sens.” control until the
target voltage is observed with the voltmeter.
9) Once you have adjusted the 500/1v2 to
its maximum low-distortion output level,
reconnect the speaker(s). The “Input Sens.”
control can now be adjusted downward if the
amplifier requires attenuation to achieve the
desired system balance.
! I M P O RTA N T
Do not increase any “Input Sens.” setting
for any amplifier channel or channel
pair in the system beyond the maximum
level established during this procedure.
Doing so will result in audible distortion
and possible speaker damage.
It will be necessary to re-adjust the
“Input Sens.” for the affected channels if any
equalizer boost is activated after setting the
“Input Sens.” with this procedure. This applies
to any EQ boost circuit, including source unit
tone controls or EQ circuits. EQ cuts will not
