High sensitivty 15" or 18"
jjones5000
Hey, me and my buddy want to set up a 15 or 18" sub for marine application. The boat just has a 50hp engine and (i'd assume) not a large alternator. We're looking for a big sub that doesn't take a lot of power to get loud. Preferrable d4 so we can get the most out of a mono-block amp. I know it's not going to get very loud on a boat (open air application). The way we're going to have it setup it water shouldn't be a concern, although moisture could be...
Anyone got any suggestions? I've checked out SS rl-p 15" subs and they look nice, but i don't know if getting an amp to do 500w RMS on the supplied electrical could cause issues.
I'm (as usual) looking for something more SQ oriented that SPL, cause i know SPL is a moot point. Just looking for something to add a little oompf to the low end.
Thanks guys, as always, you rock!
Or is it an unreal expectation to get a sub that large with a high sensitivity...
MJ 18 which is really good sounding sub my buddy has one is his car. Even tho he is runing under power it still hits really really hard like a megit hiting you in the chest. and sice you are pulling it on a boat it will be just fine
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
299
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
903
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
758
jjones5000
jjones5000
Midland co., MI
jdawg
