high sensitivity
hello hello can you guyz tell me whos subs have high sensitivity dbs, thing is ive only got about 400 500 watts and only a 4 ohm stable amp so some high dbs for under $150 a piece. is what im after
Don't worry so much about that sensitivity rating. You can find pro audio subs with sensitivities near 100db.....but they will need extremely large enclosures, and have generally poor low frequency extension.
Any sub with an RMS rating of around 400-500w will work well for you. Trying to base your decision off of a single spec, like sensitivity, is not the way to go.
i have atype r now and a old reference series(2 12s ) they are ok but , i think my type r has had it and its picky about the enclosure
well ivw had xtant, alpine, mtx, fosgate, infinity, pioneer, sony, and memphis, so i do base on more than sens but thats one aspect i never cared about about before but if its not that big o deal ,,,,than tell me a good sub thats not that picky ya know through it in any old sealed baby:up2somet:
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
95
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
662
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
582
azeasy13
azeasy13
sedona, AZ
PhatTonyDeMarco
    May 16, 2024
    May 16, 2024
