MT dustcap..will it get warm?
bamaboy
War Eagle!!!
i had been playing on and off different songs playing with the epic, and i went back to feel the mt and it was regualr room(truck) temp, i go to play some young jeezy onl aboput 25secs of actual bass, then i turned it down to go feel it just to see if it got warm, the dust cap was a little warmer than before, it isnt hot or really warm at all but you could tell it was a little hotter, this is on 16/35 and my gain was set on 21 or 22 i believe, even then it wasnt set to the fullest
people with MT have you ever checked this, i know i wasnt overpowering it because i have a good bit of headroom so clipping shouldnt be set in
HU on +1 for sub and its a clarion so does it get 4v at 0 or +5 for the sub?
and it really wasnt going at it that much
info or am i F****d?
my xxx didnt, but my rlp and av12 would get pretty hot, but they are alumnium cones, while my xxx has an outer dustcap which is a few inches away from the inner dustcap
it dosent smell, but i can feel it is a little hotter than before i didnt know if it was supposed to or not, but the heat has to go somewhere
its not really warm, i just can tell it has some heat on it
when i had some 15"s in a wall daily, id check everyonce in a while just because id get a hint of coil. They'de get pretty hot, no way near as hot as the motor tho.
you should be fine.
you should be fine.
seriously you could cook a EGG on that thing after a LIL john song
yea i dont really smell anythying so it is normal though? these arnt hot though so im good //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
so rule of thumb im safe as long as i dont smell da coil //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
and does the motor get hot? ive never played it where i could feel the motor
bamaboy
War Eagle!!!
bamaboy
Auburn, Alabama
bigbassman
