High Pass Crossover Choices
Somebody
CO
I have been researching this topic for quite some time and wanted some feedback on which high pass crossover option is best for the following set up.
I have an Alpine 9856 deck with absolutely no type of built in high pass or low pass filters and a Rockford Fosgate Punch 400a amp that has a fixed LP of 80hz and a fixed hp of 120hz. I have the subwoofer crossed over at 80hz and I tried the 120hz setting for the front speakers but the mid range was significantly cut.
The options I have considered are the bass blockers sold by outlets such as Crutchfield, but the lowest crossover point they carry is 150hz. They also carry F-MOD RCA filters, but I have read that these adapters are not the best choice. Parts Express carries some second order hp crossovers that have lower crossover points of 80hz. Lastly, I have deduced that I need a capacitor of 400-500uf to achieve a roughly 100-80hz crossover point.
Which of the above mentioned options, or others, would be the best choice, until I can replace the deck or the amp with a model offering variable crossover frequencies. My speakers are TS-C520prs components with a relatively inefficient sensitivity of 88db. I would like to preserve all possible amplifier power. Any help would be greatly appreciated.
Thanks for the response. Would this be an active or passive? Most of the active seem to be in the price range, or close to that, of a new amp. Are you talking about something similar to the in line 2nd order crossovers available at Parts Express or something entirely different?
Thanks, I missed the electronic crossover option somehow. I will try to pick up one of these and a distribution block to tap into my power wire. Are there any brands that should be avoided for the electronic crossover?
Somebody
Somebody
CO
helotaxi
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
