Radioflyer97
C.E.O.
I purchased a 200amp alternator for $475 from rushpowersystems.com in February after designing a sound system for my car. Last week the alternator gave out while driving. After talking with Darren Flint (owner of Rush power systems) he told me I could send it back for warranty repairs.
After receiving the alternator, Darren said that the unit overheated and could be fixed by replacing components that were destroyed. He also suggested some sort of coating that would cool the alternator. I informed him that this car was my daily driver and he said he could put a rush on the work required. I was fine with this assuming that it was under the lifetime warranty offered by rush power systems on their alternators. See link:
(http://rushpowersystems.com/toppage1.htm)
After talking with him today he said it would be another week before he could get the alternator back to me and that it would cost $150 to fix and that the lifetime warranty only covered labor…total warranty only lasted for 3 months. I’m suspicious that the unit itself was faulty because it failed so quickly and I shouldn’t be responsible for repairs to it. Darren claims that my system is causing the alternator to work excessively and is causing the overheating.
This is how Darren described the alternator in Emails:
“ …another problem whit your stock alternator design is there is not enough venting to dissipate the heat, the newer alternator solves that problem”
(alternator specs)
engine idle (700 to1000 rpm) 80 / 120 amps
part throttle cruse (1500 to 2500 rpms) 140 / 180 amps
power mode (2500 to 4500 rpms) 150 / 225 amps
"...for daily use for systems up to 1500 watts at normal volume.”
(regarding clutch pulley option which I requested)
“I wold also recommend our clutch pulley. with the clutch pulley when you stop at a light the alternator "freewheels" at the same speed it was turning when you were at cruse speed. this will give you a soother power curve, as well as the ability to produce a proximally 150 amps at an idle whit no power loss on the top end. this option would add $75.00 to your total.”
I’ve only had this unit since mid February and have put less than 500 miles on the car since it was installed.
The System power demands were as follows:
Peak power:
JL 500/1 – 50 amp fuse
(2) Alpine MRP F250 amps – 2x 15amp
(total of all amp fuses) 110
The JL is set at 50% and Alpines are set at 70%. I have yet to have my volume level above 50%. This means the current draw shouldn’t exceed 50 amps even during a musical peak. I also have the “big 3” using Knukoncepts KOL4 awg wire.
My car's alternator mounting setup requires a special size chassis. An OEM replacement alternator is $500 and pre-owned ones are nearly non-existant.
What would you do in my situation?
(alternator specs)
Peak power:
