high level input
optima07
i have a 07 kia optima and i need to run the wires from my high input plug to my rear speakers but those rear speakers are in the back doors what the hell do i do i really need help.............. been at this thing most of the day all of my other wires are ran.................
car___ 07 Kia Optima
h unit__ factory headunit
sub___rockford fosgate P2 10 in..
amp__Orion 600 watt 2 ch amp
wirez___monster cable 4ga wire kit
The high level input connects to the speaker wires coming from your head unit. It's an input. It will not power your speakers. Your speakers should be connected to the amplifiers speaker terminals. The high level input should only be used if your head unit does not have rca outputs.
correct but my rear speakers are in the back doors of the car and its not going to be as easy hooking them up there as it would to be to hook it up if the rear speaker was in the rear deck.... is there an easy way around it ?
It's not all that hard to remove a door panal, just be carefull not to break anything. Or if you don't want to do that just get a new head unit. Use your amp to power a subwoofer. It would sound alot better and easy to install.
optima07
optima07
g'ville sc
indosia
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
