high level... answer quickly please
  • 4
wickedmooch
do i need to hook up my high levels to something to get power through my amp... my amp is getting power but dosent give power out.. its a .....
NEW FOR 2001! 1800 WATT 4 CH AMPLIFIER ONLY $149
NEW FOR 2001! 1800 WATT 4 CH AMPLIFIER-NEW-NR
PYRAMID AMERICA
1800 WATT AMP!
NEW FOR 2001!
BRAND NEW FACTORY SEALED CARTON!
Pyramid PB1860
Product Features:
INCREDIBLE FOR SUBWOOFERS!
Four Channel Amplification
450 Watts x 4 Output
900 Watts x 2 Bridged or 450 Watts x 2 + 900 Watts x 1
Fully Adjustable Electronic Crossover Network
Variable Bass Boost (0~12dB @ 60Hz)
Soft Turn On/Off Circuit
2 Ohm Stereo Stable/Bridgeable into 4 Ohms
MOSFET PWM Power Supply
Heavy Duty Aluminum Alloy Heatsink
Discreet Wire Connections
Variable Gain Control/Remote Turn On/Off
Hi/Lo Level Gold Plated MOLEX Inputs
Power On LED Indicator
LED Protection Indicator
S/N Ratio: > 95dB
THD:
Frequency Response: 10Hz - 30kHz
Thermal/Overload/Short Circuit Protection
Dimensions (LxHxW): 19" x 2.25" x 10.25"
This is the largest amp Pyramid has to offer. ONE THOUSAND EIGHT HUNDRED WATTS TOTAL OUTPUT. Just think of the woofers you can push with this monster.
Monster? The only thing Monstrous about that amp is the b/s they did to get it to push 1800 watts. LOL, I hear a new one everyday, nothing better than a few good laughs.
You need your RCA's from the h/u to the amps input level. You also need your main power wire from your battery to the amp, with a fuse near the battery. You'll need your remote lead, and a ground wire from the amp to the chassis of your car. Then all you have to do is hook up the speaker wire to the amp, and then you'll be on your way to finding out what crock of sh!t pyramid was cooking up when they put that amp on the market.
that is a common misconception most people have about pyramid amps... they expect to get power OUT of them. lol
seriously though... the formula for calculating or converting the power in/power out ratio for a pyramid amp is approximately "((volts in) x 16) / 5 = watts out"... or in your case...
(12 x 16) or (192) / 5 =38.4 watts out...LOL ... just kidding... i could'nt resist... lol:D
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
724
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
626
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
137
wickedmooch
wickedmooch
South Lyon, MI
phattyex
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
