High db sub
Idk I've just been looking at sub specs online and was wondering if a12 can even put out that db level and how accurate are those specs anyway. Basically looking for a really loud 12" sub
bahahahahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahhahahahahahhahahahahahahhahaahahaahahahahahahahahhaahahahhaahahahahha
ok now lets be serious. First of all the db rating you are looking at is efficiency on how it produces sound. so 95db is basiccly 95% of the power you are giving the sub will be used. etc etc. doesnt have anything to do with a real pressure level
yah a 12 can do 95 db easy- i have 1 in my trunk on 1200w and have been metered at 141 db.
how many watts does your amp put out(RMS) and at what impedence(ohms) also who makes it and what gauge power-ground are you using for it?
yah a 12 can do 95 db easy- i have 1 in my trunk on 1200w and have been metered at 141 db.how many watts does your amp put out(RMS) and at what impedence(ohms) also who makes it and what gauge power-ground are you using for it?
its not even about that. 95 db is a car running its a spec. not an actual spl number
SS ted
SS ted
Rochester ny
hispls
