Hifonics Zeus 3000.1 Problem
You most likely have broke a solder joint or something along those lines. How bad did the amp get "shook up" ???
Did it fly around and smash into things inside the vehicle ? I bet it hit the input rca terminal and broke a solder joint or something like that causing a internal short.
What Mutant said is what I would do.. It could very well just be the rca sockets on the amp. I had an old phoenix gold ti 600 that had a bad rca socket and had similar symptoms.
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
MikeyL
MikeyL
Goose Creek, SC
bumpasauras
    May 18, 2024
    May 18, 2024
