Hifonics Cyclpos Viii series
Yes, you may be right,if i turn the gains up,but i am looking to run both at the 2 ohm load to keep the amps running cool cranked.I am aware of the rms,and ohms value of what i need in order to not blow my subs,just wondering if anyone has slaved any of these amps at any time in the past,or can it be done??Thanks,any information is helpful.
Says at 11.5v continuous w less than 0.15%tdh 175 at 113db!!! 2 ohm stable. I put 1 on a pair of RE dvc 1000rms 10 and it was???### my db meter went into error at 135.I have a crap load of old school amps zed made,and a few of the monster audiobahns....18001,2200hct,4125hct,means m 66 hc66,44,hc44 99,bts 7150 7154 7204,hifonics genisus cyclops ect,ect.Those amps slaved will push that 18 1200rms sub all day long without any issues at a 2 ohm load.Fuse rating at 4ohms is 20amp,and 2 ohms is 30.TRue rms power,and im at 14.4v all day with my set up.. should be interesting.Never slaved the Hifonics viii together ever.
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
audiobaun
audiobaun
USA
audiobaun
    Jun 1, 2024
    May 31, 2024
