hifonics amps
The better question is "Who doesn't have experience with a Hifonics amplifier?" //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
- Steve
The BX1000D would be plenty for most people ... however, you can use the BX1500D if you wish - just be careful with your gain, bass boost, etc. What kind and size of enclosure will you be using?
Do you plan on upgrading later on down the road?
- Steve
I had a Hifonics for quite awhile, ran perfect, as everyone puts it, its probably one of the best bang for the buck amps. Runs at 1ohm like a champ and didnt ever go into protect mode. I'd go with the brutus 1500 watt model, and just keep the bass boost at 0, and the gain low. Id rather have more power, than not enough power.
My thoughts exactly. A pair of SE's could take a good 700 watts RMS a piece, so the bx1500d would be a better choice than the 1000d.
Mine has ran perfectly for a while now, running at 1 ohm. It gets warm, but not too bad at all.
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
12
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
5
3K
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
441
F150beatz
04 F-150
F150beatz
Granite Bay, CA
tommyk90
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
