Hifonics 1610 is it overrated
Just for burps, right? It takes 50% over the rated fusing for 5 seconds to blow a fuse, so you could probably get away with even more if you're just doing a short 1-2 second burp.
I dont burp per say but that was about a 5 second section of track 2 on bass mekiniks 808 but the amp was at 2 ohm as well.
also heard mix reviews on the 2010 stuff but we clamped a 2600 08 model and it only put out 1135wrms at 1.5 ohms @12.3v.. tested same board with the aq 2200d put out rated and the cadence ia9 is a bit beefier and is underated
thats weird because my 2607 is doing ~2100 at 1.5ohms at 14volts
they had mass amounts of "bad batch's" go out hence why some 30some percent of the 08 models ran at 1 ohm fried lol glad your's works well for you!//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
me too. they worked pretty well at .5ohms as well.
as for rms at 12.3 volts, i have no idea.
My63impala
My63impala
Gainesville, GA
TopDogAudio
