BreakingBad
Banned
The problems i'm having now:
a.) BOTH bulbs can vary in brightness
b.) right bulb now goes out randomly
c.) one bulb seems to have a "pinpointed" brightness, when other seems to be more of a spread out brightness...hard to explain
3bspec (site i bought from) said this could be a potential relay issue, bad ground, etc.
What would cause both bulbs to act so erratic? Any answers will help, gotta get this fixed tomor am!
Note: I also had a new battery under hood installed (optima) along with 2 batteries connected in rear. stock bulbs worked fine with that battery setup...I'm thinking a relay issue, either a bad relay all together or a bad ground, bad connection to battery, etc. ANY ideas?!
i'm having the install shop look at the relay/grounds/battery tomorrow...is that something that could cause one bulb to be dim, the other to be brighter, to randomly turn off, and not turn back on unless i hit the switch in my vehicle...along with varying brightness on both bulbs?
