Set up my gain using the JL Audio tutorial's test tune method. Now my system sounds flat and I can barely hear the sub. I played around with the crossovers, but not sure that I have gotten the setting right. What should I set the amp's hi and low crossovers at based on the speakers capabilities? Thanks in advance for the help and LMK what other info you need to help me out!
Amp: Eclipse EA4000
Adj Hi Pass 18 dB octave: 30-500 Hz
Adj Low Pass 18 dB octave: 50-500 Hz
Front Speakers: 5 1/4" Infinity Kappa Component Speakers
Sensitivity 94 dB
Frequency Response: 55 - 25k Hz
RMS Power Range (Watts) 2-85
Peak Power Handling (Watts) 255
Impedance (Ohms) 2
Rear Speakers: 6 1/2" Infinitu Kappa 3-way speakers
Sensitivity 90 dB at 2.83 volts
Frequency Response 45 - 22k Hz
RMS Power Range (Watts) 2-75
Peak Power Handling (Watts) 225
Impedance (Ohms) 4
Sub Amp: Kicker mono ZX 400.1
10" JL Audio Dual Voice Coil Sub(10w3v2-D4)
300 w cont
Dual 4 ohm
Amp: Eclipse EA4000
Sensitivity 94 dB
Impedance (Ohms) 2
Impedance (Ohms) 4
300 w cont
Dual 4 ohm
