Hey there needing some helping choosing an amp at a fair price
Jmnofear92
Hey there,
I recently purchased two rockford fosgate p3d2-12's and I'm looking for a 0.5ohm stable amp. I have found a Lanzar DCT5001D amp. It's a 5000 watt monoblock amp which is a half ohm stable and says it pushes 5000 watts at half ohm. It has three 40amp fuses which is about 1200watts rms? Which for my subs rms is 600watts a piece with 1200watts max per sub. Is this a good find or too good to be true? Hope you can help only have basic knowledge of install and starting to try to learn more!
Thanks everyone!,
Jarred
Yes, it is too good to be true and, you cannot judge the output of an amplifier by its fusing. You would be able to if amps were 100% efficient but they are not. All amplifiers use more power than they produce and cheap amps with exaggerated power claims are notoriously inefficient.
As was said above you'd be better served to buy a quality amplifier with a modest RMS power rating, even if it cost more than the one you're looking at.
Also, don't bother looking at "peak" or "max" power ratings, even from the highest quality manufacturers. Those numbers are marketing propaganda and they are only there because consumers do not understand how electricity and power work.
There are several, if not dozens.
Some of the more experienced guys will chime and and give you some solid advice and manufacturer names shortly I'm sure.
Literally, there are so many options and I only have experience with a couple of them so I don't want to throw out my biased advice.
How about this amp?
ITEM DESCRIPTION:
OPTI2000D Optidrive 2000W Half Ohm Stable Mono Block Digital Competition Amp
OPTI2000D
Lanzar OPTI2000D Optidrive 2000 Watt Half Ohm Stable Mono Block Digital Competition Class Amplifier
700 Watts RMS Power @ 4 Ohms
1100 Watts RMS Power @ 2 Ohms
1600 Watts RMS Power @ 1.3 Ohms
2000 Watts Max Power @ 0.5 Ohms
4000 Watts Bridge Max Power @ 2 Ohms
Mono Block Subwoofer Amplifier
0.5 Ohm Stable
MOSFET Power Supply
PWM (Pulse-Width-Modulated) System
Double Sided Epoxy PCB Circuit Board
Gold Plated RCA Inputs
Custom Terminal Block for Speaker Connections
Thermal, Overload Short Protection
Remote Bass Control
Soft Turn On/Off
THD @ 1Watt/4 Ohm: 0.1%
S/N Ratio: 90dB
Frequency Response: 15Hz - 150Hz (+/-3dB)
Damping Factor @ 20Hz/4 Ohms: 400
Low Pass Filter: 50Hz-150Hz, 24dB/Octave
Variable Subsonic Filter: 15Hz-40Hz, 24dB/Octave
Variable Bass Boost: 0 to 18dB
Variable Phase Control: 0 to 180
Input Sensitivity: 200mV ~ 8V
Input Impedance: 10k Ohm
Line Output Impedance: 100 Ohm
Fuse Rating: 30A x 6
Dimensions: 10.08'' (W) x 2.12'' (H) x 19.1'' (L)
[[uPC]]
How about this amp?
ITEM DESCRIPTION:
OPTI2000D
0.5 Ohm Stable
MOSFET Power Supply
Remote Bass Control
Soft Turn On/Off
S/N Ratio: 90dB
[[uPC]]
decent amp, but I have a alpine mrp 2000 for 325 shipped
So, given your advise; do you know of any half ohm stable recommended amp for a fair price?
For sure I do. The CT Sounds line up will take a .5Ω load but as has been said, you'd be far better off with an amp that does what you need at 2Ω in a daily setup... unless you're prepared to spend a good chunk of money on electrical upgrades.
When you drop to .5Ω efficiency decreases a lot and what that means is that the amp requires significantly more current just to produce the same amount of power. So if you buy a .5Ω stable amp and don't up your electrical, you'll be buying new subs and/or amps sooner than later, because an amp that's starved for voltage will try to pull more current and that will lead to clipping and other stresses on the amp's power supply.
In the end, it's best to buy a quality amp that will do what you need at or above 1Ω. It may cost a bit more in the short run but it'll cost a lot less in the long run.
But to answer your question directly... the 900.1 will do what you need at 1Ω and more than you need at a half. The 1400.1 will do what you need at 2Ω and it will blow your subs to smithereens at a half. The 900.1 is priced comparably to the amp you posted and I'd pay double for it before I'd buy the amp you posted. ;-)
Well my plan is to upgrade "the big three" run an external dry cell battery for the amp so that the amp will not starve for power it would be getting all the power from it's own cell. Running a bigger alternator as well to replenish the power back to the batteries. So, am I half way there for electrical upgrades?
That could be good enough, depending on the amp, the wire, the batteries and the alternator but the amp won't be getting all of its power from the second battery. The alternator and front battey are a part of the equation as well. In fact, the alternator needs to be able to be the primary supply of power to the amp while the vehicle is running. The batteries are just there for additional current when needed.
Jmnofear92
Jmnofear92
Chico,ca
Freeman
