Hey im new, can you help me with my calculations?
FLAWLS1T/A
Alright guys im pretty new here and have read all of the info and stickys about making your own ported box, but i need somebody to check my claculations.I really just want to make sure that they are correct before i build the box! thanks a TON!
THANKS A LOT!!!//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Box dimentions = 37.5X14.5X11
Net Volume in Cubic feet( internal counted for .75 mdf) = 2.573
3inch port that is 36.5 inches long?
here are the sub specks..
Published Specs: XS-L121P5
Max Power (W): 1200
Max Power (RMS, W): 350
Sensitivity (dB/W/m): 89
Freq. Resp.: (Hz) 18 - 2k
Impedance (Ohms): 4
D (mm): 250
D (inch): 9.8
Rdc (Ohms): 3.2
Fs (Hz): 26.4
Qts: 0.42
Qes: 0.44
Qms: 5.86
Vas (Lit.) : 55.5
Vas (ft_): 1.96
Mms (g) : 219.0
Lvc (mH) : 1.2
Xmax (mm) : 7.5
Xmax (inch) : 0.3
BL ™ : 16.1
General Info: 12-inch Polypropylene Cone
Weight: 12 pounds 10oz
Mounting Diameter: 11.0 inches
Mounting Depth: 6.375 inches
Unique pentagon cone design.
Gold-plated Binding Posts.
Small sealed/ported enclosure optimized.
its going in this bad boy //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
FLAWLS1T/A
FLAWLS1T/A
Valencia, CA
FLAWLS1T/A
