HEx amp for brahma 10"
The X2000.2 ?It would have to be a larger box.
2.5 i think
Helix HXA1000Qx MkII
HXA 1000QX Mono amplifier with integrated parametric equalizer and adjustable damping factor
Features
* Onboard Active crossover with selectable highpass and lowpass filters at 85 HZ/12 dB/Oct. and full range
* Adjustable damping factor
* Parametric Equalizer
* Fully compatable with HELIX HCC crosscards for the additional flexibility of fully variable filters
HXA100QX MkII Specifications:
Rated output @ 4 Ohm: 1 x 350/700 Watt
Rated output @ 2 Ohm: 1 x 650/1300 Watt
Frequency response: 20-20KHz +/- 0,2 dB
THD:
TIM:
S/N: >100dB
Parametric equalizer
Center frequency range: 50 - 150 Hz
Gain adjustment range: 0 - 9 dB
Bandwidth adjustment range: 10 - 110 Hz
Phase adjustment range: 0° - 180°
Damping factor adjustable from >100 until >2000
Input Impedance: 10 kOhm
Input Sensitivity: 250 mV - 8V
Fuses: 4 x 25 A
Dimensions (H x W x L) in mm: 31.5 x 200 x 432
Weight: 3.6kg
he asks really subjective questions but acts like a subjective reply is right or wrong then acts like he knows alot . read the 2 year old tube amp thread resurfacing lol . totally funny but with his other posts i want ask him about his planned set up as far as head unit and eq/proccessing and so forth . for your utopias i would use 4 amps on 1 set 2 25x2s (tweets) and 2 75x2's(7's) and bridge each amp to 1 speaker if you want to do it all bad arsed then get a solid 600-1000 watt matching (or close to as the other amps) amp. then i would look into getting digital eqs and or crossovers.......
jonb5150
jonb5150
LA, Ca
audiolife
michigan born
    May 14, 2026
michigan born
    May 14, 2026
