Yupz go by the CEA Ratings instead of the Companies. Btw, make sure to give us a review on how it sounds. I'm still debating between this Audison 5.1k, Hertz HP2, or the Steg amps.
I'll definitely do that, and you're right -- this review of the amp backs up the ratings you gave me ...
http://www.caraudiomag.com/features/cae_0710_audison_lrx_amplifier/index.html
The following is taken from the article above --
Audison LRX5.1K Amplifier - Aftermarket Amplifier
PERFORMANCE DATA
Output power @ 1%THD, 1kHz/100Hz, 14.4Volts
Channels A 60 watts x 2 @ 4 ohms
Channels B 181 watts x 2 @ 4 ohms
Channel C 787 watts x 1 @ 4 ohms
Output power @ 1%THD, 1kHz/100kHz, 12.5Volts
Channels A 52 watts x 2 @ 4 ohms
Channels B 156 watts x 2 @ 4 ohms
Channel C 691 watts x 1 @ 4 ohms
Distortion at rated power, 1kHz/100kHz, 14.4Volts,4-ohms
Channels A 0.01%
Channels B 0.09%
Channel C 0.51%
Input sensitivity 349mV to 4.8V
Frequency response (+ 1dB)
S/N Ratio (A weighted, full 4-ohm power, min gain) 10Hz - 52kHz
Channels A -103.7dBA
Channels B -100.3dBA
Channels C -86.9dBA
Output Impedance @ 100Hz, 4 ohms 0.03 ohms
Idle current 3.8A
Maximum current consumption @ 4 ohms, unclipped 194 amps
Efficiency at 11/43 power lowest impedance 27.2%
Efficiency at full power, 1%THD, lowest impedance 68%
Crossover, Channels A & B
Highpass range 50Hz - 5kHz
Lowpass range 50Hz - 5kHz
Slope -24dB/octave
Crossover, Channel C
Range 50Hz - 150Hz
Slope -24dB/octave
Dimensions 19.25"L x 7.812"W x 2.25"H
