here I go again *strapping*
rammstein
23
AZ
Just ran into this new bit (new to me) something about strapping amps
From what I have read so far the amps should be the same and the amps
need to be built to actually do this but what I cant find is what would the output be?
Taking say 2 amps each putting 2000Watts out @4 ohms after being strapped
what is the output @4 ohms now? Also is the gain of the second amp controlled
via the master amp?
Amps need to be identical. If each amp puts out 1500@1ohm seperately, and you strap them, you get 3000@2ohms. Usually it is a master/slave setup, the master controls everything.
via the master amp?
If you strap 2 amps at 4ohm, it just drops the ohm the amps are seeing to 2ohm
Whatever theyre rated at 2ohm is what they'll put out
And yes....gain is controlled by master amp
Was just askin it was new tech (to me anyways) lol never heard of it
I have 4 subs wanted to stay away from multi amps going with a single box
wanted to ether go with one big amp or strap 2 together
trying to just have one gain so they all hit the same and at the same strength
rammstein
rammstein
AZ
rammstein
