help
this question has probably been asked a thousand times but i got 2 audiobahn flame q woofers 900rms a piece.. and unfortuntley budget has allowed me to only be able to afford a 800 watt kenwood amp KAC-7201. The amp is 2ohm stable whats the best way to wire this up to get this most amount of power to the audiobahns? All the diagrams i see dont show how to wire dual 4ohm voice coils with two woofers in 2ohm to the amp??? Right now its only hooked up at 4ohm so its only putting 150rms into each sub //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
didnt i say dual 4 ohm voice coil audiobahn flame q's ? ? LOL
its setup now to be a total of 4ohms tho. From the fosgate site shows how to wire 2 dvc 4 ohm voice coils to 4 ohm but i need 2 ohm !! so if i bridge it to the amp it will make it 2ohm ?
No, if its bridged it wont see a 2 ohm load, if wired right it will see the 4ohm load in "bridged mode" somewhere close to that 460x1 rating. You dont need it to be a 2 ohm load. someone correct me if I'm wrong. Also curios, where are you getting that you need ot run it at 2 ohms?
fullcollapse69
fullcollapse69
atlanta ga
bonesninja
michigan born
    May 14, 2026
michigan born
    May 14, 2026
