help
443flip
Are lanzar amps that bad....**** //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif I got my subs hooked up today two 15" solo baric L5's on a lanzar vibe 268 //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif//content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif and only one of my channels is working I switched the wires that are working to the other sub to see if it was connected inside the box and both subs play from that one channel do you think the channel is blown or is there something I don't know I have the subs wired like there shown in the specs book that came with the subs.....so IT'S GOT TO BE THIS PUNK A@# AMP RIGHT? //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
Very easy way to find out.....stick a DMM (if you have one) on the output terminals and measure the voltage. If one channel has no (or very very little) voltage output, then you know for sure it's the amp. Though, that definitely does sound like the problem.
Only other thing I can think of is that you have the HU's fade set all the way to one side or the other.
holy run on sentence bat man!! punctuation works, ive seen it in action before :p
byt yes, it does sound like your amp is not workin so good. and like squeak said, check it with the DMM(he snuck in while i was posting //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif )
443flip
443flip
baltimore,MD
squeak9798
